Hello Kyaw Moe,
Being you model a top down approach, yes it would not fit Asiana model, specially for Energy. I am not sure what is your model structure, but i will give you 2 examples in simplest form
Even though you model is Top-Down, LEAP is flexible enough such that you can still use total energy in place of energy intensity with one little change - set the units of main branch to "No Data". On doing this now you can enter total energy value in the Parametric Tab "Final Energy Intensity"
as you can see, there won't be Per column in this case. Thus now you can put your equation in this expression bar.
if you have model for each type of fuel, you can do it as shown in screen shot above,
if not, and have only fuel share, you can use the category with energy intensity, where you can put the energy value or equation and further below, give share of each types of fuels.
On further notes, you can add Iron and Steel energy in both demand and non-energy module, as per data available and relate them both.
Further more, you can create different scenario for each regression model, but which suits best is dependent on statistical analysis.
I hope this helps,
Utsav
