• 621 views | 3 messages Discussion: LEAP
    Topic: Generating Aggregate Data Charts in LEAP Subscribe | Previous | Next
  • Yvan Ayuketah 6/23/2021
    I came across these "aggregated charts" generated across several scenarios and years (attached below) while going through a research article. Please I need directions or explanations on how I could generate these kinds of charts in LEAP.
    Thanks for your help
  • Liya Cai 6/28/2021
    Hi Ayuketah,
    First, you'd better carefully operate the model according to part 1, 2 and 3 of LEAP training excercise in , which can be simply downloaded from LEAP website. Secondly, when the model is ready, just select the relevant branch of demand module or transformation module in the result window, and you can see above charts.
    Hope this helps.
    Sincerely,
  • Charlie Heaps 6/28/2021
    Hi Yvan,
    In addition to what other have written, I should note that you cannot exactly reproduce those charts in LEAP. Those charts have two dimensions on their x axes (scenarios and years), but LEAP can only show a single dimension on 1 axis.
    You could create the charts by first making multiple results tables in LEAP, exporting them to Excel and then using Excel to chart them.
    So in short, you can generate the values needed for those charts in LEAP, but you will need to do a bit of additional organization of the values in Excel.
