• 308 views | 2 messages Discussion: LEAP
    Topic: IBC Indicator Input Subscribe | Previous | Next
  • Huong thao Pham 9/25/2021
    Dear experienced user!
    I am working on LEAP IBC and have come to the Indicator input.
    I would like to consult you on the Indicator input for different species, e.g., under Organic Carbon InterpFSY(2013, 2.248164, 2016, 2.191797, 2019, 2.137406, 2022, 2.084902, 2025, 2.034204, 2028, 1.985231) ?From IBC: 8/13/2021 4:27:41 PM
    My questions are " How should be those values interpreted? and if the user may change the values as it is appeared to be changeable?
    Thank you very much!
  • Charlie Heaps 10/11/2021
    Those expressions are actually generated by a run of IBC. A VBS script that runs after IBC calculations are completed reads the IBC results file and then writes the results back into LEAP's indicator branches. The purpose of this is so that you can see the results without having to leave LEAP. So you should NOT change those expressions yourself since they come from IBC.
