• 451 views | 3 messages Discussion: LEAP
    Topic: End of life tires, properties Subscribe | Previous | Next
  • Estela Riveros 9/30/2021
    Hello, for the production of cement in my country Petroleum coke and End of Life tires are used.
    For End of Life Tires, what fuel do I select to model it correctly?
    Thanks for the help
  • Charlie Heaps 10/11/2021
    Hi Estela,
    I would suggest adding a new fuel called "tires" in the General: Fuels screen. You will need to supply information for the tires such as the energy content (GJ/Tonne). You will also probably need to find emission factors associated with the use of tires.
    Here's some basic info as a starting point: https://en.wikipedia.org/wiki/Tire-derived_fuel
  • Estela Riveros 10/14/2021
    Thank you so much
