• 457 views | 3 messages Discussion: LEAP
    Topic: Error in links to excel files in version 2020.1.0.54 Subscribe | Previous | Next
  • Minza Haider 12/2/2021
    I updated the LEAP to version 2020.1.0.54. After updating my model for this version, the expression links to excel files are not working. It gives an error message that the file is not found. I used the function wizard to select the file but it it gives the same error (also tried entering the expression manually). I tried to open the older version of LEAP but it gives a message that a newer version of LEAP is registered on the Windows and automatically opens version 2020.1.0.54. Is there any way I can use the older version of LEAP or fix the links in this version? Any suggestions would be helpful.
    Thank you,
    Minza
  • Charlie Heaps 12/12/2021
    Thanks for letting me know. I will investigate and try to fix ASAP. I suspect that LEAP is looking in the wrong folder for the files.
  • Charlie Heaps 12/13/2021
    This should be fixed now. Please get LEAP version 2020.1.55 here: https://leap.sei.org/download.
