• 191 views | 2 messages Discussion: LEAP
    Topic: Emission level Subscribe | Previous | Next
  • Letizia Cretarola 12/9/2021
    Good morning, we are analysing the electricity sector of Mexico and we have some problems with the emissions. They are lower than the real values, even if we used real values to compute the electricity generation. When we added the "multiple effect" in "feedstock fuels", we used the default effects for the corresponding fuels in "energy conversion". Attached there are the screenshots for emission and fuels. Coukd you help us find the error? Should we add other effects? Thank you in advance.
    Attachments:  WhatsApp Image 2021-12-09 at 11.57.40-convertito.pdf [4] ,  WhatsApp Image 2021-12-09 at 11.44.44-convertito.pdf [3]
  • Muhammad Shahid 12/16/2021
    You should include all emissions and then check your energy conversion unit. Avoid LEAP converter for unit conversion then you will find right answer.
