• 280 views | 2 messages Discussion: LEAP
    Topic: save button disable Subscribe | Previous | Next
  • Lheander Gerna 2/3/2022
    Hi! I would like to ask if someone encountered the same problem as me? I haven't used the tool for more than a year and now I'm encountering a problem with the disabled save button. My license is not yet expired until October 2022. Anyone can help me? Thanks!
  • Charlie Heaps 2/7/2022
    Hi Lheander.
    I can confirm you do have a current valid registration code, so I'm guessing you simply have not yet entered it into LEAP. Check the bottom-left corner of the main LEAP screem to see if LEAP says it is running in evaluation mode. If so, you need to re-enter your registration codes. Go to the Help: Register Online menu option to enter your license code.
