• 666 views | 3 messages Discussion: LEAP
    Topic: LEAP Modes Subscribe | Previous | Next
  • Deleted User 5/19/2022
    Dear All,
    I have selected Freedonia mode, but this mode does not give permission to change the resources never add nor delete one of them. Therefore, I need to create my own analysis from zero to end, but now I can not exit from the Freedonia mode. How can I select the optimization mode in the LEAP?
    Thanks in advance,
  • Charlie Heaps 5/20/2022
    Hi Emre,
    Sounds like you might be running in evaluation mode. That mode does not allow you to save changes or create new areas. (BTW- Freedonia is a data set or "area", its not really a mode of operation). Once you have applied for and been granted a license, you can enter a user name and registration code that will fully enable all LEAP's features including the ability to create new areas. You can apply for a license here: https://leap.sei.org/license.
  • Deleted User 5/21/2022
    Hi Charles,
    I have applied for a six-month license, and I will proceed through the evaluation mode without saving option until the application process end. I have a solution after your statements for now.
    Thank you for your reply,
