• 1591 views | 10 messages Discussion: LEAP
    Topic: Dispatch rule (percentage share) - how it works? Subscribe | Previous | Next
  • Hyungsik Choi 5/20/2022
    I want to test the dispatch rule 'PercenShare' in LEAP-NEMO optimization.
    I understand the basic logic about it, but I couldn't figure out how to define the 'PercenShare' of each technology. I expected to see a tab for share numbers, but there is no such tabs. The process hare tab seems to be the one. But is is not related to scenarios. In addition, I wonder how it is bonded by the renewable target.
    Thanks for your help.
    Hyungsik
  • Charlie Heaps 5/20/2022
    Once you've specified the Dispatch Rule "PercentShare" you can enter the actual percentage values in the variable "Process Share". Note that you may need to navigate to another tree branch and then back again to your processes to allow the list of variables to get refreshed.
  • Hyungsik Choi 5/26/2022
    Thanks for your reply. I was confused about the "Process Share" because it only exits in the "current account" and it can not be altered in scenarios. Once it is fixed in the current account, is it fixed in the whole scenario?. In case of solar in my test, the solar energy shares in my scenario results exceeded the process share in the current account. I want to know more about how it works and how it can be used. Thanks for your help in advance.
  • Charlie Heaps 5/26/2022
    The Process Share variable is visible depending on how you set the Dispatch Rule and the First Simulation Year variables. The values you specify for the process shares can vary over time and they also vary among different scenarios and different regions (in multi-regional models).
  • Hyungsik Choi 5/27/2022
    Thanks for the info. But I don't still figure out how it works. Please, tell me further information in case of using NEMO optimization. I set the "First Simulation Year" as "FirstScenario Year" or "BaseYear", but the Process Share variable is not visible in scenario tabs.
  • Charlie Heaps 5/31/2022
    What did you enter for variable Dispatch Rule? You need to enter PercentShare.
  • Hyungsik Choi 5/31/2022
    Um..I tested the dispatch rule "PercentShare" in a sample model provided in LEAP and it becomes visible in scenario tabs.
    But in my model, it doesn't work. It seems to be a complicated issue related to the software.
  • Hyungsik Choi 6/8/2022
    I tried to run the "PercentShare" again in scenarios. But I found that after optimization simulation, the tab "Process Share" in the scenario disappeared. Can I use it in the NEMO optmization mode?
  • Charlie Heaps 6/8/2022
    That variable is not relevant in optimization. Optimization calculates dispatch internally as part of its cost minimization algorithm.
  • Hyungsik Choi 6/9/2022
    Ok. Please, check LEAP if the PercentShare function in dispatch rule works correctly in scenarios. The tab "Process Share" in scenarios disappears after executing optimization simulation. I simulated it from the base year. I look forward to your feedback.
