• 1596 views | 6 messages Discussion: LEAP
    Topic: Unable to register Tsc64.DLL Subscribe | Previous | Next
  • Xiugui Wang 6/8/2022
    Hey! When I start the LEAP, Unable to register Tsc64.DLL.
  • Charlie Heaps 6/8/2022
    This is usually due to not having admin rights. You can fix this by running registerleap.bat in the program files\leap folder. Make sure you run it with admin rights.
  • Xiugui Wang 6/10/2022
    Thanks for your help. Clicking registerleap.bat still fails to register Tsc64.DLL. I need to copy the files into both directories(C:\Windows\System32 andC:\Windows\SysWOW64 ) and hit registerleap.bat then register successfully Tsc64.DLL.
  • Noe Honneylova 7/22/2022
    hi Sr.
    despite I've installed the latest updates of LEAP, but the same problem persists with the registration of the TSC.DLL. i got the warning message quoted bellow, (i appreciate your help and answer about the registration of this file whether it influences on the quality of calculations or not? ), thanks Sir in advance.
  • Marcel MOBIO 8/6/2023
    Yes! Your tip is helpful! It's a right-click (and choose run as administrator) that works for me.
  • Charlie Heaps 8/7/2023
    You seem to be using an older version of LEAP. Newer versions should fix this issue.
    Currently the latest version is 2020.1.101. You can get it here: https://leap.sei.org/download.
