• 251 views | 2 messages Discussion: LEAP
    Topic: Checking and unchecking results view series Subscribe | Previous | Next
  • Matthew Davis 11/25/2022
    I would like to know if there is a fast way to uncheck all series in the results view chart (see attached). Sometimes it is useful to select one or two series to be shown, so it would be useful to be able to toggle all to be unchecked at once. Right now, I uncheck them all one by one, which can be time-consuming if there are many series and the results need to be checked many times.
    Matt
  • Charlie Heaps 6/7/2023
    You could try choosing selected branches instead of using the check boxes in the legend.  If you save the chart as a favorite it should remember which were selected.
