• 229 views | 1 messages Discussion: LEAP
    Topic: LEAP API - NEMO Reset Subscribe | Previous | Next
  • Garrett Clark 4/11/2023
    Is there a way to reset NEMO using VBA code through the LEAP API?
    I'm running into a problem where NEMO errors while results are being calculated and am working on an error handler that will reset leap and recalculate results before continuing with extracting results from LEAP.
