• 395 views | 2 messages Discussion: LEAP
    Topic: System load shape missing in the latest version of LEAP Subscribe | Previous | Next
  • Joko Santosa 6/6/2023
    We just updated the LEAP to the latest version (2020.1.0.96). When we run the program, an error message shows up. The model has no problem with the previous LEAP version. The error message says that there is no yearly load shape in the power sector. When we check the power generation module, we notice that the system load shape tab is missing. Please advise.
    Joko
  • Charlie Heaps 6/7/2023
    The yearly System Load Shape variable is now located under the high level Load Shapes branch. You may need to edit this expression there if it did not get migrated from the older version. As a first step, set this variable to the expression ShapeDefault to get things working again. See this page for more info.
