There's a variable for each transformation process called
Maximum Availability.  That variable can either take a simple percentage number, in which case it limits the production in all time slices to that value, or you can specify a time-series expression that specifies the maximum availability in each time slice. You can use that to limit how much is produced from (for example) solar in different seasons or at different times of the day See the screenshot for an example.
You can use various functions to specify this, but probably the most useful is the
YearlyShape function that lets you refer to time-sliced values stored in the General:
Yearly Shapes library.
