• 659 views | 5 messages Discussion: LEAP
    Topic: Results for the base year only Subscribe | Previous | Next
  • Maissa Mhiri 7/20/2023
    It's my first exercise using LEAP, I want to obtain the emissions for the transformation processes but I got the results only for the base year 2021 while I used time series for all the processes from 2021 to 2030
  • Charlie Heaps 7/21/2023
    Check what you have entered in your scenario (as opposed to in Current Accounts) for variables like the Dispatch Rule and the First Simulation Year.
    One possibility is that you have set the First Simulation Year to be the first scenario year (2022) and that you are then dispatching in those years by Process Share. Perhaps you have not entered any values for the percentage dispatch? Another possibility is that the demand does not exist in future years so LEAP sees no need to dispatch the plants.
    To find out what is actually happening you will need to dig a bit deeper!
    Good luck!
  • Maissa Mhiri 8/3/2023
    Thank you for the reply
    The problem is that I entered the data for the demand as times series but then it does not appear in the results (the same thing with the electricity generation in the transformation module)
  • Charlie Heaps 8/3/2023
    See my previous answer. You need to dig into your Transformation model as well as what you created under Demand.
  • Salim CHITOU 8/10/2023
    Check your scenario
