• 599 views | 4 messages Discussion: LEAP
    Topic: stock and sales tap missing Subscribe | Previous | Next
  • John Sanchez 7/24/2023
    Hi I'm experiencing some troubles with LEAP lately. After the error message of "share over 100%" appears, the sales and the stock taps from the Demand branch in the Analysis section completely disappear and the only solution that I have found is to do a rollback to a previous version which is quite inconvenient, is there a way to run a debug test or something like that?
    as the image shows I'm in the analysis tap, and I'm currently using version 2020.1.0.101 (64bit)
  • Charlie Heaps 7/26/2023
    Sorry for the problems. I have occasionally seen the stock and sales variables go AWOL at high level branches in models where you are combining stock turnover methods with activity level/energy intensity methods.
    Usually you can fix this by navigating down to one of the lowest level stock turnover branches (normally these branches are displayed with a car tire icon). Then simply right-click on that branch and inspect the branch properties and click OK. That is typically sufficient to reset the properties of the higher level branches, which in turn should cause the stock and sales variables to reappear.
    Please let me know if this helps.
  • John Sanchez 7/31/2023
    Hi Charlie thanks for your kind answer, I tried that option, but it didn't work, the sales and stock taps are still AWOL, do you know another option?
  • Charlie Heaps 7/31/2023
    Could you send me your data set (as a .leap data file)? I'll take a look at what's going on. It may be some sort of bug. Please send to leap@sei.org.
    Thanks and apologies!
