I think we are on the same page when we say "weight" or "width" and I understand the "
Converting the % of annual energy into a corresponding power requirement". However, I am wondering if LEAP will take into account the width of the time slices when calculating results other than peak load/power requirement, such as generation output and costs.
If I could use a simple hypothetical example to illustrate my question: if we have 2 time slices (1000, 7760) and the generation profile of slice 1 is high cost and the generation profile of slice 2 is low cost, will the total annual cost be "weighted" according to the number of hours in each slice [ (cost of slice 1 * 1000/8760) + (cost of slice 2 * 7760/8760) ], or are they treated equally 50/50 [ cost of slice 1 + cost of slice 2 ]? In the former, there is a more accurate account of results. So if a time slice has a higher number of hours, it should contribute more to the annual results, in proportion to its fraction of annual hours.
