• 469 views | 3 messages Discussion: LEAP
    Topic: Editing Scale and Unit in Excel Import/Export Subscribe | Previous | Next
  • Pintoko Aji 5/26/2024
    I have a query regarding the process of editing scale and unit for fuel unit. Is there any specific way or step-by-step procedure to accomplish this task efficiently, through import/export or excel based?
  • Charlotte Wagner 6/3/2024
    Hi Pintoko,
    LEAP keeps track of units and scales, and converts them internally, as long as you correctly specify the units when adding new variables. This is also true for data read in from excel, the unit on the variable where you read in the excel file just needs to match scale and unit in your file. New fuels not in the LEAP data base can be added to the database (see screenshot), where you also specify their energy content.
    Charlotte
  • Utsavshree Rajbhandari 7/14/2024
    As per LEAP help file, you should be able to do that via excel import.
