Dear all
Hi Smail,
Dear Mr. Smail,
You need to arrange the data in a single column following the same order as in the list. Then, assign it a defined name in Excel. After that, go to Import from Time Slice Shape, and you will find it available in the options.
Eng. Mohammed
