• 267 views | 2 messages Discussion: LEAP
    Topic: different yearly shape Subscribe | Previous | Next
  • Doshanbe Kabuli 7/7/2024
    hi
    I want to use different yearly shape for different years
    how its possible to use different yearly shapes for different years in maximum availablity?
  • Silvia Ulloa 8/14/2024
    Hi, this is certainly possible. First, you would need to create multiple yearly shapes (e.g. each representing the maximum availability in each year). Then, under the Maximum Availability variable for the generation technology, you can enter an expression that interpolates between the different years and corresponding Availability Shapes. For example:
    InterpYearlyShape(2020, Solar Availability 2020, 2025, Solar Availability 2025, 2030, Solar Availability 2030)
    Where Solar Availability 2020, Solar Availability 2025 and Solar Availability 2030 are the names of the Yearly Shapes.
