• 1231 views | 9 messages Discussion: LEAP
    Topic: Range checker error Subscribe | Previous | Next
  • Alebachew Azezew Belete 9/30/2024
    Dear all ,
    During opening my LEAP all model, the attached part always appears which i cannot work for all my LEAP models. How can i solve it. I removed my LEP Area from my documents and installed LEAP again without uninstalling from the C drive but still the issue is not solved. Thank you
  • Charlie Heaps 10/2/2024
    Hi Alebachew - sorry for the problems. Next time you get this error please click the submit button. I will try to isolate and fix that problem,
    Thanks for your patience!
    Sorry - the button is marked "Send Report", not "Submit".
  • Alebachew Azezew Belete 10/4/2024
    Dear Dr.Charlie Heaps,
    Thank you, i will send you such and related errors. It happens most of the time. Thank you
  • Charlie Heaps 10/5/2024
    Hi Alebachew,
    I just posted a new version (2024.1.1.4). I'm hopeful it will fix this issue. You can download here: https://leap.sei.org/download. Please can you give it a try and let me know what happens?
    Thanks and sorry for the inconvenience.
  • Alebachew Azezew Belete 10/5/2024
    Dear Dr. Charlie Heaps,
    Thank you very much and i will install or update the new version, and will inform you the progress or the change. In addition, i didn't solve the attached one which always appears after i installed the "New versions of LEAP (2024.1.1.2) and NEMO (2.1)". Thank you.
  • Alebachew Azezew Belete 10/6/2024
    Thank you very much, range checker error is solved in my model. But the process cannot access the file because it is being used by another process part is still not solved, "ReportINI.tex".
    Alebachew
  • Charlie Heaps 10/6/2024
    I think this is due to another program locking that file. This is not a LEAP bug.
    Thank you very much for your immediate feedback and support. I will try to solve it, you are right. You are always generous.
    Kind Regards,
    Alebachew
