• 765 views | 5 messages Discussion: LEAP
    Topic: Discrepancy in Total Activity Preview vs. Data Variable Activity Level in LEAP Subscribe | Previous | Next
  • Pintoko Aji 10/19/2024
    Hi everyone,
    I'm encountering a confusing issue in LEAP when comparing the total activity preview in the f(x) analysis and the values under Result > Data Variable > Activity Level. The values in these two areas differ significantly. After rechecking, I found that the value shown in the results section was incorrect, almost four times higher than the expected value or calculation.
    Has anyone experienced a similar issue or knows why this discrepancy might occur? Any advice on resolving this would be greatly appreciated!
    Thanks in advance for your help!
  • Taylor Binnington 10/21/2024
    Hi Pintoko -
    How many separate regions does this model have?
    Are you comfortable attaching your model to this thread, or emailing it to us directly at leap@sei.org? Please refer to the URL of this thread in your email.
  • Pintoko Aji 10/21/2024
    Actually, I only have 1 region without separation as it is focused on just one province. Great, I will send it directly.
    Pintoko
  • Charlie Heaps 10/22/2024
    I can also reproduce this Pintoko. I will look into it now,  Sorry for the problems.
    I suspect that in Results view there is some double-counting of branches and subbranches going on.  I will let you know what I find out asap.
  • Charlie Heaps 10/29/2024
    This issue should be fixed now in 2024.1.1.8.  Thanks for your patience.
