• 717 views | 3 messages Discussion: LEAP
    Topic: Difference in GWP for methane according to scenarios Subscribe | Previous | Next
  • Smail Khennas 10/24/2024
    Dear all
    For one scenario the calculations are based on GWP = 28 for methane
    For a second scenario GWP is 29.8
    I have checked the unit effect , it is 28. Any explanation. If I do with Freedonia, I don't have this problem. Very likely something not correct at my level.
    By the way I don't get any message error
  • Taylor Binnington 10/24/2024
    Hi Smail -
    LEAP contains a number of default GWP values (for 20-, 100- and 500-year residence times) for all major GHGs, which include different sets of GWP values taken from different IPCC Assessment Reports (ARs). For AR5, you may further select whether the GWP values include or exclude changes resulting from climate feedbacks. You may select a single AR and apply those GWP values throughout your model, or if you wish, you may select different ARs for different scenarios. This is done through the Scenario Manager.
    Using default effects and their global warming potentials (I emphasize *default*, since these are all editable by users, and I can't say whether you may have changed any of these values or names without looking at your model), LEAP defines a pollutant called "Methane Biogenic" with a 100-year GWP of 28, using IPCC AR5 values without climate feedbacks. It also defines a pollutant called "Methane" with a 100-year GWP of 29.8 using IPCC AR5 values *with* climate feedbacks.
    Are you certain that all of your scenarios use GWP values from the same IPCC AR? And, are you certain that you are not comparing two different methane branches, perhaps one that is "Methane" and another that is "Methane Biogenic"?
  • Smail Khennas 10/26/2024
    Many thanks Taylor
    Indeed it is due to the fact that in the scenario, it was set as with climate feedback, reason was I was getting 29.8 CO2eq for methane despite I set a 28 value under effect. In another task, scenario for GWP was left blank (below) and it worked perfectly
