• 246 views | 2 messages Discussion: LEAP
    Topic: Different results with the analysis setting Subscribe | Previous | Next
  • XIAO DONG 11/18/2024
    Why the results of outputs by output fuel are totally different with my production history setting in analysis part? Do I miss some other modules? The screenshots as following.
  • Pintoko Aji 11/24/2024
    Historical production is required only for the Base Year (or up to the First Year of the Scenario, if you have more than one Base Year). If you want to define generation shares or production based on your decision, set the dispatch rule to 'percent share.' First, convert all electricity generation data into percentage shares, then input these values as the percent share. Make sure to include the total capacity in the exogenous capacity as well. Hopefully, this works.
