• 231 views | 4 messages Discussion: LEAP
    Topic: Excel export problem Subscribe | Previous | Next
  • Joaquin Perez Torres 1/8/2025
    Hello, i have a problem when i export a branch to excel. If a choose to export expression some of decimal numbers suddenly lose the coma and if a want to import that excel back to the area it takes the number without the decimals. What could it be?
  • Charlie Heaps 1/8/2025
    I’ll look into this Joaquin. This may be related to number formatting in different regions. LEAP normally adapts to your local settings but sounds like there may be an issue when exporting to Excel. Can you tell me what regional formatting you are using and specifically what are your decimal, thousands, and list separator characters?
    Hello Charlie, thank you. First i was using latin america formating wich is . for thousands and , for decimals. Then I changed it to . for decimals and , for thousands but the problem remain the same.
    Could you send me the exported file so I can see the issue? Please also tell me which exact version of LEAP you are using (e.g. 2024.1.1.9). You can send to leap@sei.org.
