• 340 views | 2 messages Discussion: LEAP
    Topic: Exporting multiple Energy Balances Subscribe | Previous | Next
  • Ricardo Aguiar 1/24/2025
    Dear LEAP developers,
    the option to export to EXCEL Energy Balances for multiple years of the 2024 LEAP version does not seem to function properly: only the "One" sheet exporting option is displayed in the interface.
    Am I doing something wrong, is there some configuration option, or is it really a bug?
    Thank you in advance for examining this issue.
  • Charlie Heaps 1/24/2025
    Hi Ricardo,
    What exact version of LEAP are you using? The option to export all energy balances did not make it into LEAP2024 yet. I will try to add that back in soon. In the meantime you could write a simple VB script to do this. Try running the following in Advanced: Edit Scripts. Set ExportEveryXYears to 1 if you want to export energy balances for all years.You could save the script as "ExportEnergyBalances.VBS" if you want to use it multiple times.
    ExportEveryXYears = 10
    LEAP.ActiveView = "Energy Balance"
    for y = LEAP.BaseYear to LEAP.EndYear
    if (y mod ExportEveryXYears) = 0 then
    LEAP.ActiveYear = y
    LEAP.ExportEnergyBalanceXLS
    end if
    next
