• 460 views | 6 messages Discussion: LEAP News Blog
    Topic: New version of LEAP available (2024.2.0.10) Subscribe | Previous | Next
  • Charlie Heaps 4/8/2025
    A new version of LEAP is now available for download supporting limited foresight optimization, a technique for simulating planning under incomplete knowledge of future events. Previously, LEAP only supported perfect foresight optimization. The new version allows you to easily create and compare multiple scenarios, each of which can simulate different degrees of foresight. Limited foresight optimization requires use of NEMO v2.2 or later (recently released). See this page for more information on how to use limited and perfect foresight optimization in LEAP and NEMO. The new version of LEAP also includes minor bug fixes and an improved help system.
  • Mohammad amin Tahavori 4/10/2025
    Hi Charlie,
    I am experiencing a very strange bug in the software. On some occasions, the Add feature in the tree is deactivated, and I have to close and open the software again to make it work.
    Amin
  • Charlie Heaps 4/10/2025
    Can you narrow this down for me?  There are times when the add button is supposed to be disabled (e.g. when you are clicking on the top most area branch or the resource branches) . Please also note which exact version of LEAP you are using.
  • Mohammad amin Tahavori 4/11/2025
    It happens usually after saving. I am using the latest version.
  • Charlie Heaps 4/11/2025
    Thanks - I will take a look.
    This is fixed now in LEAP 2024.2.0.5
