33 LikesLEAP userMatthew Davisfrom the University of Alberta has developed a new AI-based energy modeling assistant for Chat-GPT called LEAP-GPT that is designed to support scripting and automation of LEAP models. The assistant: * Provides general purpose help with using LEAP. * Guides users through using the LEAP API, including those with no prior scripting experience. * Generates code for automating LEAP tasks, including providing instructions for how to set up from scratch. * Follows best practices for LEAP API branch access, filters, data inputs, results extraction, and model calculation. * Helps navigate and apply API functions with complete argument structures. * Supports error handling and scenario/region management through scripting. To use the assistant: * Go tohttps://chatgpt.com
* Log in or create an OpenAI account. * In the GPTs tab (Explore GPTs), search for “LEAP Energy Modeling Assistant” * Start a conversation and describe your modeling task. Some example common use cases include: * General help with using LEAP. * Extracting results data. * Building branch structures and inputting data. * Sensitivity analysis. * Running batches of scenarios and various model workflows requiring iteration. * Model validation and verification. While the assistant is still being improved, it is already functional and can support real-world workflows. Give it a try. Matt welcomes your feedback!
