• 1300 views | 5 messages Discussion: LEAP
    Topic: ERangeError ? Subscribe | Previous | Next
  • Stephan Leinert 7/6/2010
    2647 Views
    Good morning,
    When trying to calculate the results for results view, I get an error message saying:
    Error Type: ERangeError
    Error Message: Range check error
    Even restarting LEAP does not help.
    Has this problem been fixed before?
    Stephan
  • Tory Clark 7/12/2010
    2640 Views
    Hi Stephan,
    This ERangeError is often an indication of LEAP attempting to calculate results for a particular set of data or favorite chart that has been deleted.
    The best thing to do is to delete the "report.ini" file found in the LEAP Area folder corresponding to the Area that is giving the error message (Documents/LEAP Areas/).
    NB: If you want to save the data in the report.ini file, simply change the name of the file to "report.old" so that you keep the data but ensure that LEAP will not read from it.
    Please let me know if this does not resolve the issue.
  • Stephan Leinert 7/13/2010
    2638 Views
    Thanks, this worked for me - great!
    Stephan
  • M Aldy Maulana 8/10/2022
    Hi Tory,
    I also have the same problem (ERangeError). However, after following your solution, my issue remains.
    Is there another solution that i can try?
    Aldy
  • Charlie Heaps 8/15/2022
    Hi all - this should be fixed now in v2020.1.74.
    Please get it here: https://leap.sei.org/download
    Sorry for the problems!
