• 1343 views | 8 messages Discussion: LEAP
    Topic: Transmission constraints modeling through database change Subscribe | Previous | Next
  • Inna Kim 5/17/2021
    Dear Charlie,
    From the NEMO's description I understood that transmission network configuration can be set through tables NODE, Transmission lines and etc.
    We could manage database change to account for transmission configuration and run the scenario by running JULIA_NEMO.BAT. I see that database was updated together with resulting tables vnewcapacity, vproductionbytechnology and etc. And now we stuck with results display, since LEAP can not read the updated results.
    Could you give an advice how to overcome this obstacle?
    Inna
  • Jason Veysey 5/20/2021
    Dear Inna,
    As you and I recently discussed, although LEAP doesn't provide access to NEMO's transmission modeling features, SEI has developed an add-on for LEAP models that enables this functionality. With the add-on, LEAP models can simulate transmission networks and power flow.
    I've separately sent the add-on to you, but I'm remarking on it here as well in case other users are interested in it. If so, please contact me, and I'll be happy to share the add-on and instructions for using it.
    Jason
  • Yvan Ayuketah 10/10/2021
    Dear Jason,
    I would love to get the add-on that provides access to NEMO's transmission modeling features. I'm currently working on generation expansion for Cameroon.
    Thanks for your consideration.
    Sincerely,
    Yvan
  • Olivia Nanfuka 10/14/2021
    Dear Jason.
    I am interested in this feature. I am currently exploring the capacity expansion for a state that has a transmission constraint between two load zones. I had largely chosen to make assumptions and not explore this aspect however, if the feature is available I would like to explore this in detail. Another question, does one need to code in Julia to be able to explore the use of this add on.
    Thank you
  • Erika Nogueira 11/1/2021
    Dear Jason,
    Could you share with me the add-on of LEAP/NEMO's transmission modelling features and instructions for using it?
    Thank you
    Erika (erika@ppe.ufrj.br)
  • Jason Veysey 11/1/2021
    Dear Yvan,
    I apologize that it took a little while for me to respond to your message. For some reason, the forum didn't notify me when you sent it. I will email you the add-on.
    Jason
    Dear Liv,
    I'm happy to email you the add-on - please contact me at jason.veysey@sei.org.
    Jason
    Dear Erika,
    Will do - I'll email you now.
    Jason
