• 53 views | 3 messages Discussion: LEAP
    Topic: Result InterfaceSubscribe | Previous | Next
  • Utsavshree Rajbhandari 3/31/2021
    Hello Team,
    While I as teaching the students to view LEAP on side by side windows view, I noticed that the drop down list in right hand side would go out of view, and even the top center drop down list would, if it is something smaller, and there is no scroll bar to get them into view.
    It is not a big problem, but it could be very handy if one could access those control tabs as well, maybe by a scroll bar, if auto moving the controls takes much of space in smaller windows.
    It would be very useful as of right now that we have to take online classes, and also could be useful in research work, when comparing the results using single screen.
    Utsav
  • Charlie Heaps 4/1/2021
    Hi Utsav - I think you've hit a bit of a glitch with the interface. It is supposed to properly place all the various elements, but looks like it did not refresh properly in this instance. Usually you can force the screen to refresh by either switching tabs, by resizing the screen or by adjusting one of the screen splitter controls. In the worst case it is sometimes worth exiting and restarting LEAP.
    FYI - I am currently working on a major revamp of LEAP's interface to allow it to fully take advantage of the new generation of high def (4K) monitors that people are starting to use. I hope to release a "high res" version of LEAP along with new high res icons and a special dark mode later this year. Stay tuned!
  • Utsavshree Rajbhandari 4/1/2021
    Thank you Charlie. You are right, it was surely a glitch. It is working properly now after the automated OS update and reboot.
    And I am already an admirer of LEAP UI, not to mention it's ever expanding functionalities/capabilities. The inclusion of dark mode sounds wonderful, I am fan of dark modes.
    I will always be looking forward for developments LEAP.
    Utsav
