• 151 views | 5 messages Discussion: LEAP
    Topic: The difference of AreaSubscribe | Previous | Next
  • Muhammad Rafif Thariq Azizi 4/2/2021
    What is the difference of Asiana and Freedonia Area in LEAP Software?
  • Utsavshree Rajbhandari 4/2/2021
    Freedonia and Asiana, although both are a sample model for LEAP.
    To my understanding, the main difference between these two is that Freedonia is meant as training exercise for beginners as well as guiding/reference for all users.
    Whereas, Asiana is specifically designed model that is required for LEAP-IBC. LEAP-IBC have specific set of requirements as well as in-built datasets, to run the model and give results.
    https://leap.sei.org/help/IBC/Using_IBC.htm
  • Muhammad Rafif Thariq Azizi 4/5/2021
    if i have already selected the Asiana Area, can i change it to Freedonia Area?
    because i'm newbie in this community sir.
    i hope you are willing to provide give the information and guidance in this discussing sir
  • Charlie Heaps 4/5/2021
    Use the Area: Open menu option to switch areas.
  • Muhammad Rafif Thariq Azizi 4/7/2021
    Thank you very much sir for the Information
